Headlamp trouble
Carnahan24
Montana
I was driving my 2015 Ram 1500 sport at night. The driver side headlight went out the whole assembly shut off. I have no high beam or low beam or park light and no blinker on driver side. The passenger side headlight has no park light or turn signal but does have. Low beam and high beam light still.
Has anybody ran into this problem? Any help would be grateful thank you.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Couple of questions
OEM or aftermarket headlights
Any accidents or other issues that might have damaged wiring.
First blush, Sound like a ground issue from your description but, have to understand other questions
blue ghost
Pennsylvania
2013 Ram 1500 sport
After to you figure out what the moderator said and see if these are problems. Check the wiring behind light to see if plug came out or a problem there exists. There should be a door so to speak in the fender well. inside you will see a white slide. this will allow you to remove light after some screw in front are removed. There are some videos on the internet to help (bulb replacement).
RamMan007
Montreal
Hello, driving a 2014 Ram 1500 Sport, I am having the same issue but with the passenger headlight. I have also notices other issues with electronics like my automatic high beams are not functioning properly.
Initially I thought it could be a ground issue but starting to think is a or fuse #10. Now I believe it could be a faulty BCM module...
Dopes any one have any thoughts ???
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
I am running aftermarket bulbs
When you say "aftermarket", do you mean you switched from halogen to the likes of LED or such?
If so, and you didn't change the type settings in the BCM with AlfaOBD, then I would suggest that may be the root of your problems.
All the power / switching comes from the TIPM (fuse box). It is chock full of electronics under the fuses and is controlled by the BCM
