Door Speaker Static
HemiBabe
DFW
I got some Rockford Fosgate 6x9s for my doors. Installed them earlier and they have a high pitched static noise coming from them. I tried switching the wires... but static both ways. What is the problem here? They are the Rockford Fosgate Punch's
[ tapatalkin ]
quietpeen
2021 TRX
Hellcat
Did you cut the harness off to wire these or buy harness adapters?
HemiBabe
HemiBabe
DFW
I cut the wires and used those butt connector things
quietpeen
2021 TRX
Hellcat
Are you sure you have a tight clean connection ?
HemiBabe
HemiBabe
DFW
i'm pretty sure... idk... I guess I can mess with it more tomorrow and make sure. That's gotta be what the problem is, huh?
quietpeen
2021 TRX
Hellcat
I'm not positive that is the problem but its a good p place to start
HemiBabe
HemiBabe
DFW
Alright, I guess I can try that... if that doesn't fix it... I have no clue what it could be lol
txbass06
NE Texas
5.9 Magnum
If that doesn't fix it, try hooking up one of your old speakers and see if it's still there. You could've gotten a bad set
HemiBabe
HemiBabe
DFW
Alright I will do that for sure. I notice the static noise more so when I turn the bass up, since I have the Infinity, I can control the bass on the head unit... would it be that I have too much power going to the speakers, or not enough power from the head unit?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
is the metal basket of the speaker touching the metal of the door grounding out?
HemiBabe
HemiBabe
DFW
Ok so I tried hookin up some Pioneer 6x9s and they have static too, but the factory Infinity speakers don't. Only difference I'm finding is the Pioneers and Rockford Fosgates are 4ohm and I'm wondering if the infinitys are only a 2ohm.... therefore I don't think my stock radio has enough power for the aftermarket speakers. Would that make sense?
[ tapatalkin ]
