Door Won't Lock
lucasgunzz
Drivers side door won't lock electronically, won't lock with the button on key or panel on door or when moving in gear. Must lock manually, any help?
Patsthebest
Had a similar problem on my '02. Rear drivers side door wouldn't lock. Broke out the voltmeter and traced to to the wiring harness as it passes from body to door. Found the break and repaired it with some soldering and shrink tubing. Good as new.
BrandoT
California
I would second this.
My rear drivers side door won't lock/unlock either. In addition, window won't roll down. HOWEVER, if I open the door everything works. I haven't gotten around to fixing it but its pointing to a break/split/ground.
Going to take the panel off this weekend and take a look.
PGFREE
SoCal
How do you get the panels off to check the wiring
