DPF-Delete items
ramhunter9
P-Star Jeep Wrangler
Looking to get power out of that CTD ...
I carry full exhaust , delete pipes , and tuners for the application you are wanting .
What is the DPF?
DPF is an acronym for Diesel Particulate Filter. A DPF works in conjunction with the oxidation catalyst and EGR valve to remove a majority of the NOx, particulate matter (think black, cough-inducing soot) and unburned hydrocarbons from burned diesel fuel. Soot is a natural byproduct from the combustion of diesel fuel. Inside the DPF is a porous honeycomb structure that catches the soot as it passes through. After the soot builds up over time, the onboard computer controls fuel injection to allow unburned fuel to enter the filter at measured intervals where it flares off and generates increased temperatures that incinerate the accumulated soot. The result: Soot is chopped by over 90-percent.
What do I need?
Step 1: EXHAUST - Select a Complete DPF Delete Exhaust System or DPF Delete Race Pipe
Step 2: ELECTRONICS - You must select an electronic performance unit for the exhaust to work properly with your vehicle.
PM me for a great price .
