Driver Side Window- One Touch Up Issue
BrBlack
Calgary Alberta
Curious if anyone has had the issue of their drivers side window loosing the one touch up feature?
Mine quit the other day. Passenger side still works.
Before i pull the door panel and start looking around i thought id ask if anyone else had this issue and how they fixed it? Don't want to replace parts casing a gremlin....
Truck is a 2010 1500.
Appreciate the help,
WilliamS
Tampa FL
This usually only happens if the battery dies. Try this, run the window all the way down using the button and hold it fully down for about 3 seconds, then pull up hard on the switch to the top and again fold for 3 seconds. Try the one touch from there.
Video of it in action.
kad
Hudson Valley, NY
5.7L HEMI
I've had this issue before, the procedure @WilliamS listed fixed it for me.
-K
BrBlack
BrBlack
Calgary Alberta
OK great. My battery hasn't died.
I'll give this a try. Thanks guys!! :)
MADDOG
Living in a Firepit
6.4L HEMI
Do the down/hold, up/hold process three times in a row.
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Happened to me a few months ago. The aforementioned fix took care of it. :waytogo:
StoneDude76
West Chester,PA
This happened to me as well. I had to disconnect my battery for a reason I forget. After reconnecting it it worked again.
Sent from my VS985 4G using Tapatalk
BrBlack
BrBlack
Calgary Alberta
It worked!!
Finally got a chance to do the reset last night.
Appreciate the help. Glad it was a simple fix that didn't require any money.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
I heard the same issue the past couple days, and just did this. I'm fixed now! Love this forum
cory733
New York
2015 Big Horn Quad Cab
Happened to me two or three times already randomly while driving, so it's not a battery issue for me.
Holding down then up like mentioned above fixed it.
shadowhawk
Southeast WI
for me, this was the first time in almost a year of ownership.
