robert kaylor
Ok my 2013 4.7 1500 is putting out barely lukewarm heat on the drivers side, passengers is hot. The truck has a single zone system.
Ive changed the thermostat and bleed the system thinking that might have been the problem. Flushed the heater core (with just water, no chemical). Thats when I realized it was just the drivers side that was the issue.
Going to try reflushing the core as I seen where the single zone systems can have issues where the lower core that heats the driver side can have some issues.
Also Ive seen conflicting info as to whether the single zone systems have the additional actuator on the rear of the heatbox that controls the blend door for the drivers side.
If its the actuator anyone have any suggestions short of pulling the entire dash to replace it. Is there a way to confirm its bad before tearing everything out.
Any other suggestions to try
