Dropped and Posi'd
HemiXpress
Hey all, it's been awhile. But I finally was able to do a Belltech 2/4 w/performance shocks and also swapped out the 3.21 peg leg rears for a 3.92 LSD.. Unfortunately, the rear sway bar didn't arrive, so I will install that later. Had it aligned right afterwards also. I also used the Spohn Adjustable trackball instead of the relocation bracket.
Before and After
dearchristopher
Galveston, TX
I wanna lower so bad but I'm afraid changing the geometry will affect the quality of ride with towing the camper I have.
and nearly no one tows anything bigger than pop ups and 16 footers with the single cabs.
anyway, truck looks sick. I bet the 3.92 swap was sorely appreciated
BlkHemi5.7
2014 RCSB
Looks great!! Do you have any wobbling issues without the relocation bracket?
15ramrt
SoCal
i had a 13 single cab before i bought my r/t and i towed 8000 lbs every weekend with my drop and helper bags. she did just fine too.
HemiXpress
HemiXpress
There is a slight wobble , but so little that it isn't detrimental. Once the swaybar is addd, it will be fine. The Sophn bar really is a good choice cause it uses the stock brackets and is adjustable.
The shop where I had it done took about 3hrs to it and did a great job as did the alignment shop. The only conflict I had was the driver side exhaut that was to close to the axle differential , so had it redone today. I am very satisfied with the way it came out and looks.:driver:
dearchristopher
Galveston, TX
car trailer, toy hauler, or what? I'm mostly thinking sway would be more present. I really wanna bite the bullet and drop though and you're making me think it would be no big deal
HemiXpress
HemiXpress
Looks great, I see you went Viper Reps. I was thinking of doing aftermarket rims, but decided against it , at least for now.
KAKA
