Dual beam 20" Lightbar installed-Help
tsunamilogan05
Gainesville, GA
Hey all just finished installing my 20" dual beam (spot/flood) light bar.
Planning on finishing the wiring this weekend if time permits and well if I have to wait on my rocker switch.
So my question is, I'd like to run this light bar with the truck off sometimes and I'm curious as to what is needed to do so?
For the switch I'm planning on ordering a comical rocker or "led light bar" rocker to place over a DPDT(DTDP) switch. Curious if you guys know if that is the switch I need to use to switch between flood or spot and still have an illuminated switch if I were to tap into a dash light.
Thanks all!
derag2
6.4 hemi
So you can use spot and flood seperate on your bar? Never seen that before.
Dirtbikekid1998
Maine
2015 1500 Laramie Brilliant Black Crystal Pearl Coat
I've never seen a bar that can be switched between spot and flood. But this is how I wired myn
I can have it on with the truck off on setting 1 then I can switch it over to 2 and have it come on with my high beams. 4d9a23dd5eafdc3abf749b0ed69ce9f7.jpg
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
If you're instructions have you wiring it to your battery via relay, it will turn on while the truck is off no problems...
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
wire into the high beams? That would be crazy!!! ;)
That's how mine is wired, manual on/manual off/auto on with high beams...
sbarron
Wasilla, Alaska
Yes... But the double switch feature is different from yours though, right?
Can you turn your bar on/off without high beams on?
IMO
only my sugar pill ambers. :roflsquared:
In reality though, I couldn't think of a time I'd want to run my big bars without the high beams... still can't.
AustinB
Banned
San Diego, Left Coast
Me either, but also considering that my light bar overpowers my high beams... I guess it looks cooler with the fogs and lows? The fact that you could change between the two with just a switch upgrade is kinda cool? Give me some time to think of reasons :)
IMO
Steve58
