E brake replacement?
EdGs
FL
Will be changing brake pads shortly on my 15 Ram 1500 (110k miles on original pads. Or at least 83k miles since I've had it).
Going to check the e-brake as well. Should I just replace the shoes and hardware?
Not having any issues with it, but might need adjustment as pedal seems to have a fair bit of travel. I use it most of the time, especially at home and work as there are slight inclines at both places.
Of course, I won'y know the condition until I get in there and look. SWFL driving mostly, no towing or heavy hauling. No boat ramps either.
Opinions?
EdGs
EdGs
FL
Also, no driving with brake on, except for a few starting to back up, realize its on, then release....lol
Daw14
South Florida
From what I’ve heard about the shoes can fail by coming apart ,if you are there with the wheel off already I would do it ,only like 35 dollars or so.
EdGs
EdGs
FL
Kind of what I was thinking, I will go ahead and pull the rear rotors and check it out
Daw14
South Florida
Lots of people report the need to remove the axles to get the shoes from behind them, this is not true, you just have to work at it a little, be patient and they will slid out for you . Good luck
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Opinions?
Don't worry about the ebrake. You won't need to change them. Not unless someone started using the ebrake to slow the vehicle down due to reg brake fail :33:
smithwessn
The lining of the shoes separated from the backing on mine. The truck probably had 35 to 40k on it at the time, although I am in the salt belt.
The parking brake kit is pretty inexpensive. It will take some patience but it can definitely be done without pulling the axle.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I have a 2015 as well. My E Brake pads fell apart :O and were never used ! Going to get them done in a few weeks even though I never use them, As far as I know my mechanic will be moving the axle but may try at first the pain in the butt way ! All I know I will not be doing it lol
joshhhh
