Easy exit seat function quit working
Nietzsche
Diesel / Hemi
After the 18.45.01 update the easy exit seat function quit working. I performed the reset procedure and the seat started working again, but it has since quit again and nothing I do fixes it. Any suggestions?
dpinvidic
This guy gets shotgun
Cave Creek, AZ
2014 RAM 1500 Limited
Did you confirm the setting in the control setup menu for Auto Easy exit is enabled?
Ricks Ram
As stated did you check and see if your easy exit seat is enabled? In many cases after an update it un selects itself. If it is selected in your settings menu deselect it for a few on off cycles and then re select it. Mine has stopped working a few time for no reason and I was able to get it working again by doing this. cce6f68eaaf083043ec29834ea49e174.jpg
N
Nietzsche
Diesel / Hemi
Thanks for the responses. I do have the setting checked in the menu. I will uncheck it for a while and then rechedk it and see if it wrks
RamCares
n/a
n/a
Hi,
We're sorry to hear that you are experiencing this concern. If you would like any additional assistance, our team is always available via private message!
Alison
RamCares
JM-Labs
