Ebiach vs belltich ?
JAlvarez10415
Wanna install a 2/4 drop kit but not sure witch one to get is it worth the extra $$$ for the Ebiach ? Any help will be appreciated ! Thanks
P.s. Will get the sway bars as well
Quicksilver337
South FL
2016 Ram R/T
this should be easy...
eibach does not make a drop spring for our trucks
most common option are Belltech or McGaughys
Rcobra427
hey sorry to change the subject but where in south fl are u from, i live in south fl too
CzBlkExp
I have read that depending on whether you are regular cab, quad cab or crew cab Belltech, ground force and McGauhys lower the trucks slightly differently. Like ground force goes a little lower on regular cabs. Mcgauhys uses the same springs I think for reg, quad so the lighter trucks ride a little higher.
I used the McGauhy 2/4 deluxe kit and was pretty happy with it as a starting point. I knew all along I wanted to go lower than 2/4 so I got that kit because it uses front drop spindles.
