efan differences
truckin151
2013 sport
What's the difference between the flex-a-light 180 and flex-a-lite 183 efans?
quietpeen
2021 TRX
Hellcat
the 183 is specific to the 2002-2008 rams. has brackets to hold the reservoir instead of leaving the stock shroud in place.
T
truckin151
2013 sport
So the 183 gets rid of the shroud all together and replaces it with one of its own?
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
that is correct. it is the one i am looking at for my truck. its more or less around the same price as the 180 as well. i talked to Duane about them a while back, he can get them.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im gonna have to check these out. Courious how they mount because its just 2 bolts in the top of the rad and 2 slip in ears for the bottom of the shroud.
T
truckin151
2013 sport
So it will move everything forward then with the 183 correct? Not sure if I can get away with that with the vararam as it sits on the overflow tank. I need to make a bracket to support it with out it resting on anything to hold it in place.
