Dominion
Check engine light came on about a month ago and I had a local shop check out the codes where he cleared them to see if they would come back. Well they did, and the codes read an EGR issue. The truck is also hesitant to get going after getting on the gas to start from stop, pauses for a moment before it gets going. I've also had it die twice in a parking lot on separate occasions, it starts right back up but I'm curious if this could be related to the EGR valve or not. Both times, it died shortly after applying gas to move the truck. All electrical was still available after this as well.
Before this check engine light started coming on, the truck had all the power I would expect and knew the truck had in a Hemi 5.7, now it's like driving a 7000lb 4 banger... I had asked around as I'm not mechanically intelligent where an individual mentioned that if the EGR valve is having issues that it could actually throttle back the engine, thus losing performance. Just curious if this one little valve could be causing this significant performance drop.
Any insight would be greatly appreciated, thanks in advance!
