FF1899
Well looking for opinions and ideas here. Yesterday I installed the front eibach front adjustable struts and 2.75 coils along with the 3 inch zone rear kit. I set the fronts to the second notch which was supposed to have the front end sitting at 3.5 inches. Thus retaining some rake but slightly less then factory. Well I have everything installed and I am sitting ungodly tail high.
Measurements being
Lf 38 1/8 rf 38 3/8 lr 42 3/8 re 42 3/4
Full tank of gas so the back being off seems about right.
I dont have before measurements because I came off of spacers however running off of average numbers posted on here the rear sound correct at about 3 inches. The front that was suppose to sit at 3.5 is only sitting about 1.5 even thought just the coils were suppose to be 2.75 themselves then on the second notch as the kit states it is suppose to be 3.5
The ride is amazing all the way around but the stance is terrible and 1.5 will not do. Has anyone else had this problem on the install. Right now CV angles are perfect so I'm thinking about jumping up 2 or maybe getting ballsy and going up 3 notches so start to bring it closer to level. Each notch should raise it .75 but my faith is no longer in eibachs measurements. Attached is the installed pic and angles of the CVS currently.
Measurements being
