- Nov 3, 2011
- 8,366
- 7,529
- Location
- Houston, Texas
- 2017
- Hemi 5.7
@FF1899 im not sure of your intentions, are you trying to do a 4” lift without the lift kit? Eibach only gives a 1” lift in the rear and you jumped to 3” the only option is to be incredibly tail high. Without pre measurements it’s really hard to do the math.
You mentioned that you had a spacer lift on there, a lot of those spacers require the top hat to be rotated 180 degrees that may be an issue but from the pictures they do look good. I would not recommend going over the 3.5 setting the amount of preload on those springs would definitely break something. If anything put the spacers on top of the eibachs.
I’m still trying to figure out your thought process? Are you trying to get it to be level? Or are you retaining your factory rake?
Mine stock was 36.75, with his only 38.375 after the eibachs he didn’t even get 2” of lift. Something is not right with these eibachs
