Eibach Pro Lift Struts
ram1500rsm
Trabuco Canyon, CA
The CV angles look pretty good, I’d guess because the op doesn’t have the pressure of the factory springs preloaded at the top perch, pushing down on the whole assembly, that’s why is much cleaner lifting anything with longer springs, especially IFS, and use preload to gain no more than 1” if needed.
Op, can you post the fender height with the new struts?
mike19950
mike19950
Delaware
Update on my fender measurements. They are 39.25" I was at 40" with the spacers. I lost a little but it's not a big deal. Also including a pic of the upper ball joint. Looks good too.7c813b2a7ed01eccb163ea2ad007a36e.jpg
dalton2425Texas
HEMI 5.7
I’d definitely look into moving that ring to 2 and have it at 3.5”! Maybe throw a 1” rear too. Angles look great...
JB1
Houston, Texas
What size spacers were they?
Mine was 36.75” stock but they do vary some
mike19950
mike19950
Delaware
I assumed they were 2.5" spacers. The physical measurement of the spacer was 1.75" when I took them out.
hodge-xj
5.9 cummins
The more I see you post details on this the more anxious I am to get this ordered. Everything looks much better than with the spacers, this makes me hate them even more
hodge-xj
5.9 cummins
I'm gonna see how it goes with their 1" rear coils and the front set to 2.75. Probably do a 1.5" BL and stuff some 37s [emoji869]
mike19950
mike19950
Delaware
eibach rear coils and shocks are next on my list too.
hodge-xj
5.9 cummins
Do you have saggy rear coils. I had to put 10psi in my bags to just level it back out
mike19950
mike19950
Delaware
I dont think so. Mine sits pretty level as it is. I dont have any spacers in the back. It does feel different in the rear now with the eibachs up front.
hodge-xj
5.9 cummins
I bet, oem shocks are like the screen door shocks on a storm door.
hodge-xj
5.9 cummins
You can, at least for the stock height setting, I think the lowest clip setting on each is close enough that's a possibility as well, but I'd have to cross reference that just to be sure. I ran eibach coils on my f150 with 5100s and there was no issue in regards to function. I'd much rather a longer spring to achieve lift over a preloaded coil.
Nick@GotExhaust
Supporting Vendor
SC
Let us know if anyone needs a quote. We offer these and can work out a nice deal on the full kit. We can also offer it separate parts as well.
Reactions: JB1
MidwestExpress
Overland Park, KS
HEMI 5.7L
Lower the Bils to the 2nd notch for 3.5” with the springs added! Man, if you have this done I’m going to be waiting for your review/feedback.
I 2nd this. Like many others, I've got 5100s front & rear currently. I'm considering adding the Eibach coils front & rear to pair with the 5100s. I just don't want to be the guinea pig, haha.
KAKA
