electric fan?
ram15
Mendocino, Ca
ive been thinking about upgrading to and electric fan for a while now because i now it gives you a little more power and some mpgs. i just dont now much about this kinda thing so should i go with a single or a dual, what size, pusher or puller, and what is a decent brand for $150 and lower price range.
bigtigga84
dela....where?
If you wanna save some money get a fan out of a 3.8l taurus off ebay. that's were i got mine. get a good controller though. some people have used hayden controllers from advance. Two burned up on me. i have a flexalite controller now but haven't installed it. running mine on a switch at the moment. it does the job just have to pay attention to the temp gauge and remember to turn it on
reddot
Wolf Point, MT
5.9 cummins
I got a full flex-a-lite kit for my cummins and love it. The best engineered kit ive ever seen. But the taurus fans are very common. Whatever you do make sure you use a shroud that seals the fan against the rad.
R
ram15
Mendocino, Ca
im looking online on the pick and pull site. they have single taurus fans and they have a dual fan also. how much room is there when you put a single in.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
flexalite black magic 180. flows 3300 cfm. comes with everything you need.
Hotroder383
Washington Mo
318 or 5.2 which ever you want
My problem with the flexalite is the price tag. I too have been looking at going with an elect fan, summit has the wiring, relays and probe for $30. I am going to a local yard today to look around and see if I cant find a medsize car like the taurus for a dual fan, gonna take measurements and get as close as poss.
R
ram15
Mendocino, Ca
yah ill probly just go to a yard and do the same, there 30 bucks for the taurus one and they put out 2000cfm.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
good luck. not enough cfm. especially if you live in a hot climate or tow. you need more. just donnt want to see you overheat your motor.
R
ram15
Mendocino, Ca
you dont think thats enough cfm? what would be a good number?
bigtigga84
dela....where?
Could change he thermostat at too if it would make ya feel better lol. i did. run a 180 with the taurus
WhiteExpress
Midland, TX
I've got a sweet... I think it's a Flex-a-lite sitting in the garage. Used it on my '00 Ram for 2 years without issue.
I'll sling it cheap! PM Me!
