Electric Running Boards
Scott DeRosa
PA
Have any of you switched or installed electric running boards on a 2016 2500? If yes what kind? How did it or is it working out for you? Thanks for your input it is appreciated.
dhulsey779
Yardley Pa
I did the AMP Research power running boards on my truck back in 18'.
Absolutely love these steps, very little Maintenace as well. There are a few different brands out there (Rough Country, Westin, Go Rhino) stay clear away from them.
Smittybuilt is also similar to the AMP boards, possibly save you $ if you go that route.
Nick@GotExhaust
Supporting Vendor
SC
We have a lot of customers that run the AMP steps and absolutely love them. There are some other options out there but AMP has been making them the longest and is always finding ways to improve them over the years. Message me if you would like a quote on Power Steps. We normally have them IN stock.
16WhiteQC
Hudson valley, NY
I have been running Amp step on my truck since 2016/17, love them.
Only thing I have had happen is that the pass side does not get as much use as the drivers. As a result I need to pull the motor in the fall, exercise the step a bunch (in and out/up and down) and lube everything otherwise the step hangs a bit in the cold (does not fully retract). Going to do the same to the drivers as well to be safe.
Would not do another truck with out them honestly.
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Ditto what the others have said. I've had my Amps since my 2015 was basically brand new and wouldn't have another truck without them. My ONLY complaint would be small rocks from gravel roads can get caught between the board and the arm, and they won't retract all the way up from time to time.
