Electrical issue
RynickG
Ca.
Cummins 6.7 turbocharged
I have a 2022 Ram 2500 6.7 Cummins.
Has anyone had problems with the UConnect system? Something is draining my batteries.
Need input . Thanks
rule18
Admin
NY
2017 Rebel
Moving this thread into the 5th Gen Heavy Duty section.
06 Dodge
Forest Grove, Oregon
6.7L CTD
Need input . Thanks
I have not had major Uconnect problems after dealer found out the factory had installed the wrong Uconnect code, once code was replaced no more problems, also no problems with battery draining...
R
RynickG
Ca.
Thank you for your response much appreciated. The dealer has replaced the batteries 2 times , both batteries and the last time it was at the dealer they said they upgraded the software on the UConnect System. I opened a claim with Chrysler after the second time it was at the dealer , just in case my batteries are drained again. As a test , I did not use and start my truck for 2 1/2 days . My truck started after being stationary for 2 1/2 days. Hopefully the dealer service team solved the issue with the software or code upgrade.
Thank you again for your response.
