Recommendation for a muffler, a resonator, or both, to reduce exhaust sound.
Jorge7289
Puerto Rico
******* 6.7
Hi, Thanks
Hello, greetings to all. What option do you currently recommend to silence my 2018 Ram 2500 with a 6.7 Cummins engine and a straight exhaust pipe?
hemihustlin
Lower Southwest Quebec
Hi, Thanks
Please double check the measurements but usually the delete pipes for those years are 4 inch diameter. also its pretty straight especially in the rear section before the axle where mufflers are typically mounted on pickups. in my opinion you could easily mount pretty much any reasonably sized center in-center out muffler
go to your local medium/heavy duty truck garage they should have what you need and be able to install it if you want
