Electrical issues
RWC2012
started having some issues with electrical system first there was a CF code flashing on the trailer break and a check 4x4 on the dash then the power locks did not work then the cruise control will turn on but not able to set speed then one day I started the truck and the wipers were on high and couldn't turn them off then I found a device that the dealer installed for security I un plugged the 4 wire harness all symptom's went away but the breaks lights are on without applying the break I went to the Dealer they wanted to charge me 130.00 just to diagnose I left after an oil change and the CF code and Check 4x4 came back on after month of not showing up did the dealer screw me and what can I do ? how do I get this fixed is this an known issue ?
