Electrolysis
bpolly2004
Missouri
Hi all. 2009 ram 1500 5.7. 215k
In 2 years I've had to replace my radiator and heater core. I am about to have to change out the heater core again. No heat on drivers side. I've flushed it and it got hot for a couple days and now it feels like ac blowing on me. So I tried to measure the voltage of the cooling system with my multimeter. In dc mode the reading was all over the place. In ac mode it was at .010. So I don't think electrolysis is my problem. What else could cause this?
1999 White C5 Coupe
Are you sure it is the heater core and not a temperature mode door misadjusted or sticking or with a bad actuator?
Take a look through the HD section,and do a search on here,there's probably 50 threads on the issues you're dealing with
White six four
Wisconsin
Did you flush the whole system or just the heater core? If you didn't flush everything there still could be crap in the system that keeps floating around til it makes its way to the core and clogs it.
cdn cj
Canada
If you’ve got heat on one side not the other, it’s not the core.
Ramez
phoenix
use an air water flush gun and push into the block the crud will come out if the lower radiator hose.
Burla
Army
2010 Hemi Reg Cab 4x4
The best part of rmi-25 is it insulates the cooling system from electrolysis, it also takes any contamination and traps it in over flow tank. Once you open it you need to use the entire bottle it doesn't store well once o2 hits it.
rockyj69
