Emergency need help
Egor
Baltimore, MD
My dad has a 2012 2500 with 35x11.5x20 trail grapplers and hes in a pickle long story short ....can he pull a 10000 lb fully loaded fifth wheel which the truck if not can we upgrade anything to make it possible??? Gears, suspension, prices . Help help help
What engine, trans and axle ratio?
He would probably want Load Range E tires if they are not already.
Devin1349
is the 10k lbs after the 5er is loaded or is that when its empty because also is the 2500 a diesel??
E
Egor
Baltimore, MD
5.7 not sure trans and axle 10k after loaded
ScottFL
U.S. Navy Gulf War Vet
2016 RAM 1500 Laramie Longhorn 4X4
HEMI 5.7
Plug the VIN into this decoder (LINK) and then click on the Tech Specs tab to see the tow rating.
ScottFL
HEMI 5.7
If you do not know what axle is installed, first click on the equipment tab, this will tell you what was factory installed. Then the tech spec tab will let you know the max load for your axle.
