Engine rebuild
Hagar1
Ontario Canada
2012 Ram 1500
So .... I've started on the hemi rebuild, back in the day, I used to clearance the small block chevys at about .002" and found a couple of benefits. Reduced friction and less potential for scuffed pistons.
Does anyone see a problem with doing similar on the hemi?
Ken226
Washington State
If your talking about the main bearing clearance, .002" is right about the middle of the spec. Not too tight and not too loose.
2 thousandths seems to be about what most aim for on the cylinder wall clearance too. For cast pistons anyway.
H
Hagar1
Ontario Canada
2012 Ram 1500
Thanks!
Well, I'm on my way with the build part. I should keep a camera handy to keep a photo journal of the process. At my age, I probably won't be doing a bunch more of these.
Yes, I am documenting all the clearances etc.
Crappy Tire still has the Haynes manuals in stock,and they might be a worth while investment for clearances,as they do have differant clearances depending on which rod bearing you're checking the clearance on
I copied this from another site,but it'll get you in the ballpark.
Stock clearences.
Crank mains. .0009-.002 Thrust .002-011
Rods .0007-.0029
Ring gap .0118-.0157 top
.0137-.0236 second
.0079-.028 oil control steels
H
Hagar1
Ontario Canada
2012 Ram 1500
Stock clearences.
Rods .0007-.0029
.0137-.0236 second
Thanks for that! I subscribed to the Mitchell diy program and I have the Haynes manual along with the "New Hemi Engine" by Larry Shepard. My ribbon feeler guages required some searching but I tracked them down. I bought so fresh plastiguage both green and red. Dug out my micrometers and I'm just having a ball! I had to file all the rings because they were on the tight side. Better a bit loose than too tight. I ran a wire through all the oil galleries and then ran a "bottle brush" through everything. Tomorrow is crankshaft day and maybe install the piston and rod assemblies. I need to make up a tool to act as a "stop" for #1 piston so I can properly find TDC, then I'll install my degree wheel.
I'm having fun ........ no service manager breathing down my neck with the "when will it be ready?"
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Found this 1 elsewhere also...........
SPECIFICATIONS
Eagle Engine - 90° V-8 OHV
Metric / Standard
Displacement 5.7 Liters / 348 CID
Bore 99.5 mm / 3.92 in.
Stroke 90.9 mm / 3.58 in.
Compression Ratio 10.5:1
Max. Variation Between Cylinders 25%
Firing Order 1-8-4-3-6-5-7-2
Lubrication Pressure Feed - Full Flow Filtration
Cooling System Liquid Cooled
Cylinder Block Cast Iron
Cylinder Head Aluminum
Crankshaft Nodular Iron
Camshaft Cast Iron
Pistons Aluminum Alloy
Connecting Rods Powdered Metal
CYLINDER BLOCK
Metric / Standard
Cylinder Bore Diameter 99.50 mm / 3.92 in.
Out of Round (MAX) 0.0076 mm / 0.0003 in.
Taper (MAX) 0.0127 mm / 0.0005 in.
Lifter Bore Diameter 21.45 - 21.425 mm / 0.8444 - 0.8435 in.
PISTONS
Metric / Standard
Clearance
Measured at 38.0 mm / 1.5 in. Below Deck 0.031 - 0.058 mm / 0.012 - 0.023 in.
Ring Groove Diameter
Top Groove 90.4 - 90.6 mm / 3.56 - 3.57 in.
Second Groove 88.4 - 88.7 mm / 3.48 - 3.49 in.
Weight 413 grams 14.56 oz
Piston Length 53.3 mm / 2.10 in.
Ring Groove Width
No. 1 1.23 - 1.26 mm / 0.048 - 0.0496 in
No. 2 1.23 - 1.25 mm / 0.048 - 0.0492 in.
No. 3 2.03 - 2.05 mm / 0.079 - 0.080 in.
PISTON PINS
Metric / Standard
Clearance In Piston 0.005 - 0.014 mm / 0.0001 - 0.0005 in.
Diameter 24.004 - 24.007 mm / 0.945 - 0.9451 in.
Length 62.99 - 63.21 mm / 2.47 - 2.48 in.
PISTON RINGS
Metric / Standard
Ring Gap
Top Compression Ring 0.40 - 0.55 mm / 0.015 - 0.021 in.
Second Compression Ring 0.24 - 0.51 mm / 0.009 - 0.020 in.
Oil Control Rails 0.15 - 0.66 mm / 0.0059 - 0.0259 in.
Side Clearance
Top Compression Ring 0.04 - 0.09 mm / 0.001 - 0.0035 in.
Second Compression Ring 0.04 - .08 mm / 0.001 - 0.0031 in.
Oil Control Rails 0.06 - 0.21 mm / 0.002 - 0.008 in.
Ring Width
Top Compression Ring 1.17 - 1.19 mm / 0.0460 - 0.0468 in.
Second Compression Ring 1.17 - 1.19 mm / 0.0460 - 0.0468 in.
Oil Control Rails 0.387 - 0.413 mm / 0.015 - 0.016 in.
CONNECTING RODS
Metric / Standard
Piston Pin Bore Diameter 24.014 - 24.024 mm / 0.9454 - 0.9458 in.
Side Clearance 0.10 - 0.35 mm / 0.003 - 0.0137 in.
CRANKSHAFT
Metric / Standard
Main Bearing Journal Diameter 64.988 - 65.012 mm / 2.5585 - 2.5595 in.
Bearing Clearance 0.023 - 0.051 mm / 0.0009 - 0.002 in.
Out of Round (MAX) 0.005 mm / 0.0002 in.
Taper (MAX) 0.003 mm / 0.0001 in.
End Play 0.052 - 0.282 mm / 0.002 - 0.011 in.
End Play (MAX) 0.282 mm / 0.011 in.
Connecting Rod Journal Diameter 53.992 - 54.008 mm / 2.126 in.
Bearing Clearance 0.020 - 0.060 mm / 0.0007 - 0.0023 in.
CAMSHAFT
Metric / Standard
No. 1 58.2 mm / 2.29 in.
No. 2 57.8 mm / 2.28 in.
No. 3 57.4 mm / 2.26 in.
No. 4 57.0 mm / 2.24 in.
No. 5 43.633 mm / 1.72 in.
Bearing To Journal Clearance Standard
No. 1 0.040 - 0.080 mm / .0015 - .003 in.
No. 2 0.050 -0.090 mm / 0.0019 - .0035 in.
No. 3 0.040 - 0.080 mm / .0015 - .003 in.
No. 4 0.050 - 0.090 mm / 0.0019 - .0035 in.
No. 5 0.040 - 0.080 mm / .0015 - .003 in.
Camshaft End Play .080 - 0.290mm / 0.0031 - 0.0114 in.
VALVE TIMING
Intake
Opens (BTDC) 28.2°
Closes (ATDC) 239.8°
Duration 268°
Exhaust
Opens (BTDC) 274.2°
Closes (ATDC) 15.8°
Duration 290°
Valve Overlap 44°
CYLINDER HEAD
Metric / Standard
Valve Seat Angle 44.5° - 45.0°
Valve Seat Runout (MAX) 0.05 mm / 0.0019 in.
Valve Seat Width (finish)
Intake 1.18 - 1.62 mm / .0638 in.
Exhaust 1.48 - 1.92 mm / 0.0583 - 0.0756 in.
Guide Bore Diameter (Std.) 7.975 - 8.00 mm / 0.3134 - 0.315 in.
HYDRAULIC TAPPETS
Metric / Standard
Body Diameter 21.387 - 21.405 mm / 0.8420 - 0.8427 in.
Clearance (to bore) 0.020 - 0.063 mm / 0.0008 - 0.0025 in.
Dry Lash 3.0 mm (at the valve) / 0.1181 in. (at the valve)
VALVES
Metric / Standard
Face Angle 45.0° - 45.5°
Head Diameter
Intake 50.67 - 50.93 mm / 1.99 - 2.01 in.
Exhaust 39.27 - 39.53 mm / 1.55 - 1.56 in.
Length (overall)
Intake 123.38 - 123.76 mm / 4.857 - 4.872 in.
Exhaust 120.475 - 120.855 mm / 4.743 - 4.758 in.
Stem Diameter
Intake 7.935 - 7.953 mm / 0.312 - 0.313 in.
Exhaust 7.932 - 7.950 mm / 0.312 - 0.313 in.
Stem - to - Guide Clearance
Intake 0.022 - 0.065 mm / 0.0008 - 0.0025 in.
Exhaust 0.025 - 0.065 mm / 0.0009 - 0.0025 in.
Valve Lift ( @ zero lash)
Intake 12.0 mm / 0.472 in.
Exhaust 11.70 mm / 0.460 in.
VALVE SPRING
Metric / Standard
Spring Force (valve closed) 435.0 N +/- 22.0 N @ 45 mm / 97.8 lbs +/- 5.0 lbs. @ 1.771 in.
Spring Force (valve open) 1077.0 N +/- 48.0 N @ 32.6 mm./ 242.0 lbs. +/- 11 lbs. @ 1.283 in.
Free Length (approx). 55.6 mm / 2.189 in.
Number of Coils 7.95
Wire Diameter 4.95 × 4.1 mm / 0.194 - 0.161 in.
Installed Height (spring seat to bottom of retainer) 46.0 mm / 1.81 in.
OIL PUMP
Metric / Standard
Clearance Over Rotors (MAX) 0.095 mm / 0.0038 in.
Outer Rotor to Pump Body Clearance (MAX) .235 mm / 0.009 in.
Tip Clearance Between Rotors (MAX) 0.150 mm / 0.006 in.
OIL PRESSURE
Metric / Standard
At Curb Idle Speed (MIN)* 25 kPa / 4 psi
@ 3000 rpm 170 - 758 kPa / 25 - 110 psi
* CAUTION: If pressure is zero at curb idle, DO NOT run engine.
H
Hagar1
Ontario Canada
2012 Ram 1500
SPECIFICATIONS
Metric / Standard
Camshaft Cast Iron
CYLINDER BLOCK
Metric / Standard
PISTONS
Metric / Standard
Clearance
Ring Groove Width
PISTON PINS
Metric / Standard
PISTON RINGS
Metric / Standard
Ring Gap
Side Clearance
Ring Width
CONNECTING RODS
Metric / Standard
CRANKSHAFT
Metric / Standard
CAMSHAFT
Metric / Standard
VALVE TIMING
Intake
Opens (BTDC) 28.2°
Duration 268°
Exhaust
Opens (BTDC) 274.2°
Closes (ATDC) 15.8°
Duration 290°
Valve Overlap 44°
CYLINDER HEAD
Metric / Standard
HYDRAULIC TAPPETS
Metric / Standard
VALVES
Metric / Standard
Head Diameter
Length (overall)
Stem Diameter
VALVE SPRING
Metric / Standard
OIL PUMP
Metric / Standard
OIL PRESSURE
Metric / Standard
Thank you! I'll try to print this!
EdGs
FL
You're moving quicker than I am on my cam and lifter job, lol. Going into month 5 for me.
Life has been kicking my a$$ lately, so I can only work on it on the weekends.
H
Hagar1
Ontario Canada
2012 Ram 1500
Well, I'm retired and have been so since 2007. It is motivation that I have in short supply. I keep putting it off until tomorrow. I sort of like procrastination because I have nothing to do today buy plenty to do tomorrow. ....... I think that is how it works. :D
H
Hagar1
Ontario Canada
2012 Ram 1500
So, back to the serious side for a moment, I see in the mitchell diy specs: cam phaser bolt 72 ft-lb and a Camshaft sprocket bolt 90 ft - lb. Are they not the same bolt?
Ok, Thank you! Any suggestions on holding the cam while torqueing? I already have the chain in place and double checked.
You can buy a plate that locks the cam,but if you want to torque it today,you can also stuff some smaller rope in a cylinder to jam a piston,or use something to grab and lock the crankshaft flywheel/flexplate to stop it from turning
H
Hagar1
Ontario Canada
2012 Ram 1500
Heads are still off or I would go that route. I think I'll just use my "piston stop" that I made for finding TDC. That will work.
I'm not putting the heads on until the engine is sitting in the truck. I think it might be easier that way because I'm not removing the AC Condenser.
The old "rope" trick worked good for valve seal replacement, but I usually just got the engine up to TDC and pressurized the cylinder. Never had one get away on me. Now, playing around with airplane engines was a different thing. Always get someone to hang on to the prop when doing a cylinder leakage test.
Personally i'd put the heads on while they're easy to put on,and you have more room to properly install the pushrods and rocker arms.It's alot easier to get the rocker shafts on while you can stand beside the engine,then it is while leaning over the front end or fenders,just ask @EdGs :Big Laugh:
