crazy_luck
Developed a problem.
No CEL, but my scanner shows a pending code of P1411 - drive train failure.
Happened after I made a left turn off of a freeway onto a country road. Truck accelerated just fine until it hit 60 and then it was like hitting a brick wall - no more accelerating. Truck started vibrating like crazy as soon as I let off the gas. Pulled over, shut it off, restarted it and it was good for a few miles then it started acting like it had a speed limiter of 60mph and would shake and shudder at light throttle conditions, almost like a timing issue.
Just googling the p1411 code, looks like all the possibilities of this problem suck - everything from a failed MDS solenoid to broken valve springs or collapsed MDS lifters...
Looking at the extended EVIC screen, the oil pressure was normal, but the oil temp might have been a little high at about 205°.
After I got home, I parked it and went in to research the code while eating dinner - I will go out and inspect it after I eat, to let it cool down some. Anyone think at this point it's still safe to drive it?
