Excellent information! Thankyou.Any 03-08 2500/3500 and 03 1500 5.7 will be a plug & play drop in (no MDS, no EGR). The 03 engine will require use of your intake manifold, as the 03's is slightly different and uses different injectors. 04-05 1500 engines will work but you'll need to block off the EGR ports since your 2500 doesn't have it. 06-08 1500 engines have both EGR and MDS, so you'd need to block off the EGR ports. Luckily, the default mechanical position for MDS is off; without a computer capable of activating it, it'll never engage. Just ensure you leave everything in place (do not pull the solenoids).
