engine swap
prettyaz
Lake Havasu city Arizona
1999 ram 1500 5.9 4x4 & 2002 ram 5.9 4x4
5.9 mag
Hi, so i have a 02 ram1500 5.9 4x4 i want to take that engine and install it in a 99 ram 5.9 4x4
the omly real difference im noticing is the radiator,oilcooler,condensor, power steering cooler, fitment and location are a bit different, also the 99's trans is vacuum operated verses the 02 electronic. The tranny in 02 is shot so would like to leave original, trans & trandfercase in the 99. Any input would be greatly appreciated.
FF376
Quinton VA
Base engine should be the same. You will need to use your original front engine accessory drive and wiring harness..
Raadz
