Erratic Idle......?
PinkCamoDodge
Out in the Boondocks!
Magnum v8 5.9
Well, here lately my truck hes been idling erraticly. I'll crank her up, and while she's sitting there just idling, the RPM's will go up to a bit over 1,000, then drop back down to the normal level, as if I were revving it., but my foot isn't touching the pedal. It does it in Park, Drive, and I could feel it do it even when I was in Reverse. Any of y'all have any ideas what could be malfunctioning? I dont think it's a huge deal, but it still makes me nervous, as I don't want to get stranded anywhere if the problem excels. Thank you all in advance. Everyone is always so helpful here, and I really appreciate it.
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Probably your idle air control valve, or the passage and plunger are dirty and need cleaning.
The IAC is on the back of your throtle body. You can remove the two torx screws that hold it on and clean the plunger and passage the plunger seats against.
If this doesn't help, you'll likely have to change out the IAC. This is when I recommend a dealer part. Aftermarket IACs suck.
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
Thank you so much!
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
Is this something that could cause me to break down at some point? Or does it only affect the idle? I'm gonna call for a price on that part but depending on the cost I may not be able to afford it right away like I'd like to....
