Erratic tach
RHeller
usa
Anyone else have an erratic tach? I am out of warranty, and not sure where to begin
Racer_X
Have you checked for any codes? Could be a symptom of a misfire or other issues.
Sent from my hammer and chisel using Tapatalk
Hemi395
Cape Cod MA
I can't remember if it's the crank sensor or cam sensor but the tach gets it's signal from one of those. I want to say the crank sensor maybe check the wires at that to make sure it's not rubbed and make sure the connector isn't corroded.
Another thing you could do is hook up a scan tool that reads live data and see if the actual rpms are fluctuating. If not it's most likely the guage itself...
R
RHeller
usa
i did hook up my scan tool which does live readings. The RPMS are pretty steady, they flucuate a bit, maybe 5-10 rpms. but the small fluctuations on the reader dont coincide with the tach fluctuations at all. I am thinking at this point its just a bug in the guage itself. the truck doesnt miss a beat and idles real smooth
cody mummert
Pa
i just seen mine do the same thing today !
Hemi395
Cape Cod MA
Well that sucks because the only way to replace the tach is to replace the entire gauge cluster which requires a dealer to flash the mileage onto the new one. An independent mechanic might be able to do it if they have the proper equipment...
R
RHeller
usa
I can live with it...it only does it at idle, and works as it should while driving. just an odd bleep every once in a while
joshhhh
