ET20 for stock/leveled 1500?
BigDogg795
Ronkonkoma, NY
So I plan on buying new tires by the summertime since I've hit 25K on the factory Goodyears and I want to consider buying new wheels to go with them. I'm not looking for anything flashy (honestly if it wouldn't weigh a metric **** ton I would commission a set of 20" steelies to be built lol). I found one set of wheels I like; they measure out to 20x9 ET20. Now I know that'll fit stock no problem (from what I've seen stock is ET19), but what happens when I level out my truck? I don't think I'm going to go to 35's; if I decide to go bigger on a tire it'll probably be 34's. Mostly likely I'll stick with factory sized 33's, either way I want to level out using the Bilstiens though.
Should I forget the ET20's and find something that's got 0 offset or will I be alright?
BlownGP
Houston/Baton Rouge
You should be fine with 34s on a +20 offset wheels.
