Evic problem
Pucknuts
Central Oregon
Evic started flashing then went blank. Anyone know how to fix? It will come back on every now n then butvl its fer a sec or two. All fuses good.2015 2500 6.7l Laramie
Sent from my SM-G986U using Tapatalk
Mordechai
St. Pete, Florida
Bad battery?
Sent from my ONEPLUS A6013 using Tapatalk
I'd pull the EVIC and check the wiring harness, maybe the plug is loose
Pucknuts
Pucknuts
Central Oregon
Wire harness tight. Conection look good.
It started flashing one morning while warming up on the way home lights come on and it stopped flashing but the 8.4 nav screen was dim. This went on for 4 days
Then it started rapid hyper flash if the light weren't on for about a week now nothing.
Sdpadrez
Buy a new one.
Pucknuts
Pucknuts
Central Oregon
Thats the last option! Wanted to see if anybody heard of this problem!
Mordechai
St. Pete, Florida
Did you ever get this resolved? Forgot to mention but if you have Alfaobd, you can go in and just codes. Some CAN errors will produce symptoms like you have
Pucknuts
Pucknuts
Central Oregon
No still a blank screen. What should i check fo with Alpha OBD
Pucknuts
Pucknuts
Central Oregon
Evic screen came on today while i ran around town stayed on each time i started the truck up. 4 hours then nothing!
Jantelaw
