Exhaust Brake sticking in the on position. 2012 ram 2500, 6.7 L, automatic trans, 4x4, 145,000 miles
William Moraca
66246 Lakeshore dr. Dowagiac Mi. 49047
6.7 liter cummins
I purchased the truck Aug of 2019. the truck came with DPF delete, EGR delete, cold air intake, Cat delete. locking front hubs, rear air bags. The problem I am having is the exhaust brake is sticking. it doesn't matter if I am towing or not. The dealer has no idea, being there is no codes sent.
cash4acres
4lb pompano
6.7L,660ftLbs=G56 Manual 6 speed
BBQ cleaner in hot side of he351 or he300 when cold. Soak it 2-3x & every 25k miles. I get 27-33 MPGs & rarely use the exhaust brake. $25 brake pads cheaper than turbo brakes. & RED brake light goes on with brakes. NOT with turbo brake.
Sent from my LM-X410(FG) using Tapatalk
mtnrider
Georgia
What do you mean it's "sticking"?
bm02tj
B C Canada
Get some lube from Pac Brake and lube the shaft and pivots
TMFMK
