Exhaust leak or a pulley or something rubbing? Vid below
dmullenex
Durham nc
Sounds like something is rubbing but I can't tell, hopefully someone has had this issue before, it's louder under truck then being under hood.
Daw14
South Florida
Remove belt and see if anything changes, use a dowel rod or long screw driver to place against suspect parts , as in pulleys , idlers , alternator.
Check heat shields on exhaust manifolds .
dmullenex
dmullenex
Durham nc
Will check all of that once I get home, also do you know why my oil pan would still be leaking? I replaced the oil pan gasket and the oil pan, still has a leak in front of oil pan, and it's not a small leak either...... harmonic balancer going to the crank looks dry so I can only assume it's the oil pan still????
dmullenex
dmullenex
Durham nc
Seems like timing cover to oil pan is still leaking...... about ready to burn this truck to the ground
