Stuffpower
Looking to replace the exhaust. I’m seeing a lot of conflicting info. What are a lot of you guys using.
I really like that afe option. But it’s part number is for the 14-18. But then it also says it’s for the 2021? Do they all fit the same?
Had the pipe cut ahead of the muffler added a magnaflo #12288 and had the dual outlets 45 degrees down so the sound just floods around the truck. Wake neighbors loud at startup to scary aggressive growling. Co-worker said it sounded great while a block away…Magnaflow say's their 19200 catback will fit. I run one and it's fairly tame until you get on it.
Good deal. The community in this area is raising hell about loud car exhaust, street racing, and so forth. As a liberal bastion, the local govs have hamstrung the cops. There's like three of four HellCats and Demons running around in a pack terrorizing the roads and their exhaust are super aggressive, blacked-out windows, and wild graphics. They run like a Secret Service motorcade, just few inches between bumpers and always moving in unison. A long convoy of Harley's with off-road exhaust or straight pipes have nothing over these Hellcats.Had the pipe cut ahead of the muffler added a magnaflo #12288 and had the dual outlets 45 degrees down so the sound just floods around the truck. Wake neighbors loud at startup to scary aggressive growling. Co-worker said it sounded great while a block away…
I don't see anything on their website for the 2500 6.4. do you have photos and sound clip?I installed the new AWE system sounds great and no drone and almost quiet at highway speed
And my wife did not kill me
My 2 cents: 2018 Ram 2500 Power Wagon; I installed a Magnaflow 19200 cat back system. Fit well, easily installed. Looks great! Sounds great. I wanted a free flow exhaust, for my pavement princess. I tow a travel trailer at some 9000 pounds loaded. It had a drone at around 2000 RPM, which when towing was very annoying to this semi deaf, old fart. I spoke to Magnaflow and they suggested a adding a pre-muffler to the system, which I did, I inserted a 14161 race muffler (as suggested) before the 19200, the only issue was that the pipe support in the area between the cats and 19200 system is not used due to the location of the 14161 muffler. The drone is gone at the 2000 RPM mark, but can be heard at 1500 RPM at the beginning of a hard pull while the truck is in 6th gear. Once it drops down to fifth all is good BTW the towing mileage did increase by almost a mile per gallon.
Gotchya. Yea 4.56 gears are almost an absolute must with even stock gears and this damned 6 speed!When I first starting towing with the PW I would just leave it in "D" I found the tow mode not efficient and held the gears too long. I would get into 6th on flat portions of the highway, and eco mode when coasting. The most recent "pull" to the MOPAR nationals (Poconos to outside Columbus Ohio) I put the truck into 6th and left it there. Most of the time it spent in 5th sitting around 2200 RPM, which I liked. I wish these newer PW had 4.56 gears in them. It would down shift into 4th going up hill, resteep hills it would find 3rd. I do not pull over 65 MPH and average 63.
I would just lock it in 4th to tow so the engine stayed high in its torque curve. I viewed 5th and 6th as just overdrive cruising gears with no load and that seemed to make towing more pleasant. Hated all the down shifting and did the same with competitors gasser too. My tow needs went up and now I’m in a 3500 dually. The RFE transmission is MUCH better with the diesel. You can tell it was designed for the diesel and they just figured out a way to make it work with the gasser.Gotchya. Yea 4.56 gears are almost an absolute must with even stock gears and this damned 6 speed!
