Extra wire harness in doors??????
king99
Lakewood, IL
Switching out my speakers and came across a harness, wired from same loom as wires going to speakers, wrapped in white, taped to a spot that looks like a Module would mount. Green wire w blue tracer and blue wire. Power tow mirror?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
infinity? in a 4th gen........nope.
quietpeen
2021 TRX
Hellcat
the tow mirrors use the same harness as the regular mirrors
K
king99
Lakewood, IL
I don't know what it's for. There is def a spot for whatever it plugs into to mount. There are 2 holes that look like you could screw something into to mount. I buttoned up the door b4 I could snap a pic. I'm finding Kicker (besides Mopar parts) don't make a drop in 6x9. 5.25 fits w a bracket. Cutting the plastic that the window track is secured to just doesn't sit well w me. Not sure if I want to weaken that structure. Could be wrong but I feel like spacers would sacrifice sounds quality w the gaps between the speaker and where it mounts. Idk, I could be wrong.
MADDOG
Living in a Firepit
6.4L HEMI
You can still get a decent sounding shallow speaker. I believe max depth in the front doors, because of that structure, is 2 7/8"
jbmobbs
murfreesboro, tennessee
well whatever high priced system them there new dodges gots, alls i knows is the second and third gen dodges gots the infinity systems in em , i aint much on them there new high priced vehiculars lmao
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
did I just hear a banjo?
reefguy89
laurel de
Miami Son
Banned
Port St. Lucie, FL
2012 Ram 1500 Sport Crew Cab
I put spacers on my DS693s and while the triaxial part does touch the door panel, they sound great and I didn't have to hack up the inside of the doors.
K
king99
Lakewood, IL
Did you put them in the front doors or rear or both and what size spacer did you use? I think i saw someone post 1/3"? I'd rather not have to return them.
Miami Son
Banned
Port St. Lucie, FL
I used them in the front and they are 1/4" thick. In the rear I modified the opening to make them fit since there was no issue with the window track.
