Factory Air Ride w/ lift?
apeck5173
STL, IL side
I recently picked up a 2017 1500 eco diesel 4wd with the ram factory air susp.
What brand lifts are you guys running with this set up?
not sure If I just want a leveling kit or to get a 4inch lift for it.
Got 1
Des Plaines,IL
5.7l v8
As far as I know you have 2 options for our suspension: BDS or AEV. Also some people are using adjustable links for the leveling sensors.
I have BDS and never been happier. Last time when I checked AEV was on sale for $1500 I think.
Both brands are great quality.
rpr
GA
2014 Ram Limited
Performance Accessories (PA) also has (or had) a 2.5” body lift for the air ride. Thanks what I have on 2014 Limited. It’s a good kit but it’s a bit light on height for me. I had adequate clearance with just that kit with 35” Mickey ATZ’s, but I get some rubbing in the lowered positions with 35 Nitto Ridge Grapplers.
I also have to use the links on the front to level and get rid of the rake, but the links really stiffen the ride too much for me. If I had to do it over again I would definitely go with a different (higher) lift than the 2.5 PA.
