Factory mud flaps wearing through paint
GSSS
Minnesota
I took off my mud flaps and found the are rubbing through the paint a little. When I put them back on, I ran a bead of silicone clear adhesive along the edge to cushion it and keep it from chafing. Is there a better solution, other than removing them?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
3M clear vinyl. you can get it at a auto part store.. A common issue and several thread about it .. Easy to install. Remove flap. Wash area, spray with a soapy miixture.. Not sure about of soap maybe a few drops, allows you to move the vinyl around, Use a old C.C. to flatten and remove bubbles.. You tube has some videos on doing it
Damion
2019 Sport
I put some thin foam tape behind mine
Like others have stated, some clear vinyl. The HuskyLiner molded mudflap I bought came with precut clear vinyl paint protectors.
hotrod45
Home
Baby shampoo. There are quite a few different thicknesses of the 3M product and it comes in various forms. Beware when shopping for it and make sure you get what you want to work with. It's pricey stuff, especially for the heavier product. If you find some that's cheap, you'll discover that it is also very, very thin.
IronCity
Toms River, NJ
Can you post a pic?
IronCity
Toms River, NJ
I did not take a picture when I had it apart.
I was wonder bc when I bought my truck a noticed a line of paint removed from that area. Originally I thought it was dirt build up arriving the 3m take but after my first wash it clearly wasn’t.
