Factory trailer brake
GaryR3500
Brick, NJ
Cumins
Hi I have a 2022 ram 3500 I ordered and had it built, got the trailer brake controller put in. does it have EOH in the controller or do I need to change it. I have a 40 FT RV I would like to put hydraulic disc brakes independent suspension on the trailer, can I use my brake controller.
2003F350
6.7 CTD
1. Yes, it is capable of electric over hydraulic braking.
2. Why would you want to put independent suspension and hydraulic brakes on an RV? If everything is properly sized and maintained, the electric braking system is more than adequate, and I don't know that I'd want independent suspension on one - partly because the axles are designed to work together in bearing the load.
G
GaryR3500
Brick, NJ
Cumins
The IS is less violent trailer, moving the wheels move up and down in a frame stays basically straight no pumping you don’t know how violent RV trailer gets inside. I’ve had things fall off refrigerator door opening. Independent will eliminate that plus the maintenance on leave spring bushings pain in the neck even when I grease them every two months the bushing still go bad and depends have to be replaced and I’ve had one leaf spring break already thank you
