PhilW55
Installed the Fass titanium signature system on my 2004, left the stock filter housing in place but unplugged the stock lift pump. For those that have done this install, what did you do about the fuel heater system on the stock filter housing? Is it an issue?
Also when mounting the pump and filter under the front of the bed do you just use the single bolt or install a second bolt on the L bracket? I'm thinking of putting in a second one for better security and piece of mind, will need to make a threaded plate to fit up in the front bed support.
Sent from my Pixel 2 using Tapatalk
