- Apr 7, 2014
- 1,176
- 605
- 2015
- Hemi 6.4
A bit of a difficult day for the dyno operator but at least I have some initial numbers and a screenshot. For reference, I have ARH catted long tube headers (awesome!), Magnaflow 19200 cat-back, a HF 93 tune, Moe's 87mm tb, and the air intake tube mod. The dyno was a mobile Dynojet unit and they had no fan for cooling whatsoever. Outside temp was about 85 and the humidity was around 42%. Running 285/65r20 KO2's on the factory 20" rims. Still waiting for an email with all the charts/details
First runs were the best, but I never saw them or took a screenshot. HP was 370ish and torque was something over 400. Later when I realized he was having trouble retrieving the initial runs I started taking screenshots. Best I captured was 365hp/382tq, but the motor was obviously hot at this point. Still the torque curve was nice and flat, much better than any EcoBoost or Cummins charts (jk ST). Not sure what's up with the A/F, need to review the logs to see if it's the tune or the dyno probe. Way too lean for my liking. I did a couple of runs with the stock ECU to help determine how much the HF tune is gaining vs stock. The best stock ECU run in 3rd was 343hp/353tq, but I don't have a tuned 3rd gear run available yet to compare against.
Was not able to get anything reliable below 3500rpm as the truck would constantly downshift, even if I selected a gear. Not sure if others have found a good workaround, but I couldn't figure anything out. I made runs in 3rd and 4th gear, but with the stock ECU 4th is pretty useless as it hits the 105mph speed limiter. Matt(Moe's) suggested pulling the ABS fuse but that didn't help unfortunately.
The only stock dyno charts I can find on a Ram 6.4 are from K&N (293hp/269tq) and MBRP (316hp/320tq). Obviously dyno's vary and K&N vehicle was a 3500, not that it should matter much. But regardless it's pretty obvious that the exhaust mods are giving huge HP and TQ gains over anything else I've done so far.
