Finally weighed my trailer.
Loudram
Just a sinner saved by grace
South Jersey
I bought the Better Weigh scale a few months back and I wasn't sure if I could trust the weights. So today I went to a local feed store that has a public scale and had my trailer and truck weighed. I was on my way to the campground so I figured this was the best time. I didn't ask for individual axle weights bit I got the basics. Truck weight, tongue weight and combined weight. They normally charge $5 but he didn't even charge me that. This isn't a cat scale but it's accurate enough.
So the weights are
Truck 5720 without me. (5350 curb weight)
Tongue 1160
Combined 13320
Trailer 7600
So I'm at my GVW without me in it. It had a full tank of gas at that time. So I'm over a couple hundred pounds with me in it. I could leave a few things home or put my cooler in the trailer. I'm not to worried about that weight, I just have to watch it. Maybe lighten the the front of the trailer. It's a rear kitchen so that helps the tongue.
On some measurements the scale app I bought was pretty close. (Tongue weight and truck weight). On the combined weight it was over by 1000lbs. Before I weighed it, I guessed based on dry weight and what we put in it it weighed low to mid 7k and I was pretty close. I thought 8500 was heavy.
To be honest I was surprised that a 650lb dry tongue weight turned into 1160 so fast.
I finally have some solid numbers.
AFMoulton
Nuevo Mexico
Also maybe look and see if you can relocate your batteries.
2018 Ram 2500 6.4L 4x4
Amsoil SS 0W-40
Loudram
Loudram
South Jersey
There really isn't anything heavy up front. I'll have to pull everything out of the front storage and weigh it. The difference between dry and wet is 500 lbs.
In my head in thinking
60 equalizer bars and hardware
50 battery
40 propane
So far. That leaves 350. I might be able to lighten that a little bit but my only outside storage is the front pass thru.
AFMoulton
Nuevo Mexico
I bet your hitch and hardware is closer to 100# mine weighs about 175 total
Amsoil SS 0W-40
Sandevino
North Texas
HEMI 5.7 eTorque
Something definitely amiss or your trailer weighs more than expected. My father-in-law’s Starcraft was billed as a dry weight of 8500 pounds with a 5W pin weight of 1100 pounds - roughly 13% of the trailer weight.
We drug it across the scales when he took delivery, completely empty and dry, and found it weighed 9100 pounds with a 5W pin weight of 1700 pounds - nearly 19 percent.
I’m saying this to make a point that you may be chasing your tail trying to eliminate weight, and trailer manufacturers often flub their numbers.
Have you weighed the trailer dry? Weight your truck with and without the trailer to get the accurate tongue weight.
Loudram
Loudram
South Jersey
Amsoil SS 0W-40
I didn't include the hitch itself. Technically that's payload not tongue. When I disconnect my trailer that weight stays with the truck. And yes that's 50 too. Total set up is about 100 pounds. Looked up shipping weight on the equalizer website.
Loudram
Loudram
South Jersey
That crossed my mind to. I didn't weigh it dry. I think they may have been a little light with the numbers in the brochure.
I'll do what I can and live with the rest. Compared to what some guys in here are towing and some of the numbers I've seen on RV forums, a couple hundred pounds is nothing.
And the truck with the trailer hooked up was 6880. The truck dropped to 5720 when I unhooked it.
Edit
I also remembered that my electric tongue jack, while it came with the trailer, it isn't standard. More weight added to the brochure numbers.
dhay13
Edit
Yep. And not sure but dry weight may not include the AC unit? awning? spare tire? Just thinking out loud here. But if those aren't included in dry weight then I could see it adding up. But that wouldn't add 600lbs to the tongue weight.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Not suprising. Stuff adds up fast and you have a big trailer. Your totally maxed out.
I personally wouldn't worry about being a little overweight, so long as your under GRAWR, you should be ok. Perhaps a trip to a cat scale where that can be confirmed is in order because that is important.
I was maxed out with a half ton also, which is why I went 2500. One of the Best moves I've made. They are not for everyone though. Good luck
Loudram
Loudram
South Jersey
Yep, I'm maxed out on payload but I knew I'd be close with a 1500. I'll just watch what I put in my bed. As for my tongue, I'll move what I can but it won't be much. Honestly I'm not to worried about it, I'll just keep it in mind when I load the trailer.
The scary thing is there is only a small percentage of us towing trailers that actually know our real numbers or care about them.
Loudram
Loudram
South Jersey
They are included. The only thing not included is the battery. Empty propane tanks are usually included to. But my trailer weight isn't an issue. I'm no where near my max tow.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Yep, exactly. That's the issue. Most half ton trucks will run out of payload long before they hit their tow rating. But if you stay below GRAWR you should be ok
Sherman Bird
Houston, Texas
The scary thing is there is only a small percentage of us towing trailers that actually know our real numbers or care about them.[/QUOTE]
Do say!
Loudram
Loudram
South Jersey
If you want to scare some sense into someone you know have them search for towing fails or something to that effect on YouTube. It's eye opening.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Yeah man, no doubt. Some of those are crazy...scary stuff.
When I tow I try to stay 55-60 mph on the highway and just take my time. There's no rush. When towing especially.......excessive speed kills.
Most ST trailer tires are speed rated to 65 mph. Exceed that for too long and overheat them and bad things happen.
Even if my tires were rated for higher speed I wouldn't. Sadly many tt newbies do not understand the weights and mass involved and controlling that in an emergency situation.
The faster you go, the less reaction time you have. Even with properly adjusted brakes, when your rolling down the road 10-15k combined weight, it takes longer to stop that weight.
I always take towing my tt seriously. It's serious business and should be treated as such.
Just my .02 after many years of towing and seeing more than one rig rubber side up.
dhay13
I'm 51 and actually towed my first trailer at about 12 years old with my dads 1876 F250...lol. Yeah, just towed it around the hay fields while him and his buddies loaded the trailer. Yeah it was a 4 speed too but I had started riding motorcycles when I was about 6 so knew the concept of a clutch. Anyway, started towing for real at 16. Never paid much attention to weights, just loaded my trailers so they looked level and towed good. Started drag racing at about 20 and towed car trailers from then on so not real light loads. Never had an issue and never paid much attention to my weights until I started towing our current boat (~9000lbs). Weighed it last year and had about 8% tongue weight. Boats typically have less tongue weight due to the engine being at the back.
tron67j
Maryland
Wow, that is the winner for age on a truck. 1876!
tron67j
Maryland
My friend delivered trailers, among other things for years. He said that manufacturer often had the dry weight rated then installed what were considered add ons, and these were things like awnings. Those external items were not always considered part of dry weight.
Might want to go ahead and weigh axles if you can when loaded to make sure front axle weight isn't too light. Thanks for posting the information, good to read the real world measurements.
Loudram
Loudram
South Jersey
My better weigh scale has a weight distribution set up. It shows the balance of weight on both axles and the trailer to. I'm very level. The green is where I should be. The red is where I am.
