Ken226
- Mar 12, 2017
- 2,293
- 5,933
- Location
- Washington State
- 2013
- Hemi
The last few times I've needed to weigh a trailer tongue, for load balancing, I used the old simple beam/bathroom scale trick. But that gets annoying, dragging out concrete blocks and a 2x4, the calculating the sum of moment to get the scale factor.
So I started shopping around for a tongue weight scale on Amazon, and wasn't really liking the spring contraptions available. Except the Hydraulic Sherline LM1000. That thing looks pretty nice, but also $$$.
Then I spotted a few chunks of scrap out in the shop, from old projects, years ago, and decided to try and make one.
I already had everything needed on-hand, except the 1000 psi pressure gauge, which was 9$ on Amazon.
I turned the body from a chunk of 3" 6061-t6 rod and the 1.128" (so it would have a face area of 1 square inch), dia hydraulic piston from a piece of 1.5" 4130 chromoly rod. I used my parting tool and added two o-ring grooves, then milled a small slot for a retaining dog point screw.
The dog point set screw will keep the piston from slipping out, if someone picks it up by the piston.
I got it all assembled and filled with AW 32 hydraulic oil.
With a 1 SQ inch piston and a 1000psi pressure gauge, the weight to pressure ratio will be 1:1, so a reading of 500psi means 500lbs of weight.
I tested it by standing on it. It showed my weight perfectly.
So, my cargo trailer weighs 2500lbs empty. The tongue shows 270'ish lbs. 11% of it's weight on the tongue.
And, no leaks! I'm happy with the way it turned out, even if it does look like some kinda gothic steampunk sex toy.
I'm in it for the Amazon 9$ gauge, 2 hours of time, about 25cc of oil about 20$ worth of metal leftovers.
