First Problem in 5 years 2016 2500 6.7L Diesel
smrovell14
NJ
6.7L Cummins
So I use my truck to work and today on my ride down to a job the check engine light came on and then off. So I thought it was nothing maybe from the truck sitting for the last week.. However while making my way home towing a dump trailer no less I lost all power and I could hear air pushing out of somewhere. Also the turbo was running very little pressure.
I found the air was coming from out of the turbo into a (rubber or silicon) hose, and the hose had slipped off and the Clamp was missing, I went and got a hose clamp to just limp it home. Now it builds pressure however it sounds like air is forcing out like a bunch of off tune trumpets(sorry for the poor comparisons) is their any way to seal the connection better so that air doesn't leak or do I need to replace the entire hose/pipe. Ive tightened as well as I can. It only has 37k miles on it and I just want to do it right I depend on it, and really don't want to bring to the dealer if I dont need too.. Its a 2016 2500 Tradesmen 4x4
It's possible the hose was damaged when it blown off. You'll probably want to buy the factory replacement clamp as it's probably capable of clamping the hose tighter without distortion. Check the other connections if you haven't already
S
smrovell14
NJ
6.7L Cummins
As soon as I put the temporary clamp on the truck drives normal, Im ordering the clamp now, Im thinking about replacing the hose completely but the parts can even be pricey.
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
DELETE
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
Seems as if I had heard of others that have had that hose blow off.
Jus10case
