First time mods. Lift/level/widen 2015 1500 V6
Jason119Mesz
Barrie
Hi all! First time posting in the forum, looking to get some advice on levelling/lifting and widening my 2015 1500 4x4 v6. I just purchased a set of rims and 275/ 60 R20 BFG ko2’s to replace the stock 17’s. Looking to give the truck a little more aggressive look along with improving its off-road capability’s. Not getting into anything major off-road just a little bushwhacking and beach cruising, think a level and or lift will help and a widen just to complete the look. At the same time I don’t want to go too crazy. ( In regards to both the look and the cost) I appreciate the advice in advance, would love to see pictures if you’ve got some and if you’ve got any specific kits you could advise on purchasing that would be a bonus!
Cheers!
Usa
Cheers!
For something small go with the Bilstein 5100 kit and if you want to keep some factory rake get a spacer or new coil spring in the rear. It'll look pretty nice with those wheels
J
Jason119Mesz
Barrie
Will I need new UCAs if setting the shocks to 2.1 or less?
crazykid1994
Generally 2” or less your uca should be fine. Bilsteins are a good quick cheap option. I’m running bilsteins 5100 myself in my v8. I like them quite a bit. Haven’t run anything else but they suit my needs. I’m running aftermarket coils on the bilsteins as well which changes the ride characteristics a good bit but being your v6 I’d stick to the 3rd or 4th clip especially with 275/60r20s or it’ll make them look small.
