Jeepwalker
- Joined
- Sep 8, 2017
- Posts
- 3,295
- Reaction score
- 3,527
- Location
- WI
- Ram Year
- 2012 Reg Cab, 4x4
- Engine
- 5.7 Hemi
A certain benefit of the RFE is there's a dipstick and easy to check/change the tranny fluid.
Are you saying that informed buyers are avoiding the 6-speeds? From my research it looks like both tranny's have been offered in 2500s since 2013. Is the 6-speed considered an overall lower quality transmission?
I bought my 2017 1500 in 2018. Had 23,000 miles, was a former rental. I looked it over and drove it, seemed to be in great shape. Still had the balance of the 36K warranty, so I figured it would cover any issues.I see quite a few of them, but they are ALL prior rentals. If private owners are selling or trading them, I don't know where they are.
Yup. From what I've seen the 66rfe has some pretty signicant valve body wear issues.The 8 speed is night and day better in every way than the 6 speed. Find a ‘19 or newer, be patient, you’ll track one down.
Get the 8 speed if you can find one.Hi all. I'm eyeing a 2018 Laramie 2500 Hemi with the 66RFE. I'm a total rookie when it comes to Rams, and the Hemi 6.4 seem very hard to find right now, so I'm trying to learn fast so I can act.
It has 3.73 axle ratio and I'll be using the truck primarily for weekend trips pulling a 5000 lb 25' travel trailer.
I've driven a '19 with an 8 speed and it was great. How does this 6-speed tranny stack up? It won't be my daily driver. I'll just be pulling a 25' trailer on occasion.
Anything else I should check for before pulling the trigger? I'm just trying to buy it with eyes open.
Thanks!
I have a 6sp that has a column shifter and I can put it into manual shift mode with the controls right there so I can choose the shift points and disable the MDS at the same time. Does your 8sp do that??There is absolutely zero reasons to get the 6 speed.
Yes, it does.I have a 6sp that has a column shifter and I can put it into manual shift mode with the controls right there so I can choose the shift points and disable the MDS at the same time. Does your 8sp do that??
I have to agree, I pulled a 6500 lb travel trailer with 2 different 1500's 5.7 8 speed and it pulled like a dream. And guarantee lots better mileage when I wasn't towing with the 1500.....don't over do it. I do highly recommend a load leveler hitch, it makes all the difference.25’ and 5200# towed occasionally? I’d buy a 1500.
With an 8 speed.
I thought they were dial select only...??Yes, it does.
Yep. And nobody needs a 2500 Ram to tow a 6,500 lb trailer.I have a 6sp that has a column shifter and I can put it into manual shift mode with the controls right there so I can choose the shift points and disable the MDS at the same time. Does your 8sp do that??
Not true. Stop spreading fake news. They influenced other OPECe members to follow their lead and not increase production just because the US publicly and the EU privately asked for an increase. Meantime no one really knows what Russia is producing but it has not decreased materially as expected. This is causing prices to ease.Be patient. Saudi Arabia cut down oil production and prices are creeping up. If the trend continues, I suspect there will be more 2500 hundreds to choose from.
Hold on. Huntergreen’s info is no more inaccurate as yours. OPEC which Saudi Arabia is part of did cut oil production in November. Russian oil production had little effect on domestic gas prices as the U.S. and Canada are sanctioning Russia for the Ukraine war. Russia produces about 10% of global oil and their biggest buyers are China and India. The US is pumping record oil production in 2022. Gas is dropping because several refineries that were out of service over the summer for maintenance, repair or damage are back on line and producing gasoline not Russian oil. Global demand for gasoline has dropped because of recession fears and high inflation further bringing domestic gas prices down. My point is you snapped at huntergreen for fake news because in your estimation they gave inaccurate info when your info wasn’t 100% either.Not true. Stop spreading fake news. They influenced other OPECe members to follow their lead and not increase production just because the US publicly and the EU privately asked for an increase. Meantime no one really knows what Russia is producing but it has not decreased materially as expected. This is causing prices to ease.
There are still and will continue to be shortages of diesel and other mid distillate like kerosene, and gasoline largely because of refinery and storage capacity issues.
OP said he also wants to haul a heavier travel trailer at times.Yep. And nobody needs a 2500 Ram to tow a 6,500 lb trailer.
My 1500 Eco Diesel has:
8 speeds,
No MDS (Mad Derangement System) on a diesel,
Manual Shift buttons on steering wheel,
Tow/Heavy duty button modifies shift points,
The highly convenient out of the way fun Spin O-Matic dial shifter on the dash,
3.92 gears,
tow capacity of 10,800 lbs
cargo capacity of 1600 lbs.
I can engage the cruise control in the mountains while towing a 6,500 lb trailer and kind of forget its back there.
While a gas engine revs higher (and is considerably noisier in the mountains) a properly equipped 5.7 Ram can tow and carry about as much, if properly equipped.
You don't need a 2500 Ram.
I would just like to add a clarification. The gear limit is not a manual gear selection. It only limits the top gear the truck will use. A manual mode would be more useful to me. The truck will still automatically shift between gears up to the top gear you specify.They are, but the steering wheel has the manual gear select buttons when you have the 8 speed. Look down and right from the horn, you'll see "gear limit" and the +/- buttons.
