Fitment Question
Jameson
Fort Benning, GA
My plan is to replace the HBS 2" spacer for Bilsteins set at 2.8" and throw on a 1.25" BL (I Have Amp steps so can't go 3"). Also thinking of throwing in a small spacer out back and matching shocks. I was just going to run 33" MTs on the stock wheels but now I'm thinking of either getting a set of x10s or x12s. My question is will I rub with 33s and x12s or x10s (4.5" BS) and 4" of lift? I'm still a Dodge noob. Thanks
king99
Lakewood, IL
I am doing the same. Pulling my leveling kit and swapping for Bilsteins front and back. I already have 1.25" BL and I am waiting for (on back order) my 35x12.50 Trail Grapplers on 20" XD Misfits. Only difference is I went with 20x9 (stock size) for my wheels. Personaly not a fan of the overly wide look, but with that set up and 35's I will clear lock to lock. I believe I am correct in saying that stock tires are 33". I would turn wheel lock to lock and measure how much space you have before you would rub. That should give you a good indication of how wide you can go. Not sure if that helps but I am sure someone else will chime in soon as well.
J
Jameson
Fort Benning, GA
I think 20x10 will be a good choice, thanks for the help. Any idea what stock 20" Laramie wheels are going for?
quietpeen
2021 TRX
Hellcat
i currently have 33x12.5x20 tires on 20x10 wheels with 4.5" backspacing and that would fit on a stock height 4x4.
