Vinnie1986
Hey guys, had a quick question here. Yes I've read through previous posts and seen some fixes but wanted to ask anyways. Recently replaced my water pump and thermostat about a month ago. I went with a carquest 203° thermostat ( mistake I know ) anyways the coolant temp has been pretty good fluctuating between 188-199°. Today on the way home driving on the highway I noticed it got all the way up to 215 and stayed there for a bit than finally dropped back down to 192° after I turned the heat on but that could have been a coincidence. Being a mechanic I'm gonna guess and say the thermostat or the sensor might be a little suspect. Any of you guys using a 180° thermostat? Any noticable drop in gas mileage? Was thinking of changing it out for a gates or stant T-stat. Thanks!
