Fluid Capacities
Guzzirider
hey I have 60K on my 2016 1500 outdoorsman and need to change the axle and transfer case fluids
the owners manual is useless and no capacity info, what is the capacity of T case and front and rear diffs
Thanks loving life in Durango
caulk04
Supporting Vendor
You'll need 2qt for the tcase.
If memory serves, 4qt will do both differentials.
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
I posted this same Q in the MOPAR forums with my VIN and they got back to me with everything I needed to know
Basically you'll need 2+ quarts, but you only FILL to 1/8" below your fill plug on level ground... depends on how much your drain out too.
I also bought one of these to use in getting out any metal crap in the bottom
