For Sale Zex nitrous kit, complete with accessories
Status
Not open for further replies.
charonblk07
Calgary, Ab
F1-A forged 349ci
Selling a complete single nozzle ZEX kit, ZEX window switch, purge solenoid, 2 full bottles with 1 bracket (full if picked up locally); Glowshift nitrous gauge w/ pressure sensor, and each bottle has a bottle heater. Asking $1000 + shipping.
andymac40330
Is there anything at all additional needed to get this kit up and running?
Crescent1101
Tampa, FL
3.0L ECODIESEL
Did you run this on a stock motor? How much were you using? Where did you mount the bottles?
andymac40330
+1 I'd be very interested in how you had this all set up as well
My biggest concern is where to mount the bottle and the switch panel. My initial thoughts are bottle under the rear seat (doubt it will clear) or in the bed (hate to lose space in an already short bed).
charonblk07
charonblk07
Calgary, Ab
F1-A forged 349ci
The only thing you might need is a basic switch and some wire to tie everything in. I can throw in a switch but you'd want to wire everything in yourself.
I ran a 125 shot on the stock engine and a 175 on the supercharged/forged engine. Bottle was mounted in the bed and there's enough -4an feed line to reach the back of the bed.
If it's a single cab it will fit behind the seat, you just want to put a hole in the floor and run the blowdown tube; it won't fit under the seat, hat much I know since you NEED to have the bottle angled to keep the siphon tube in the liquid nitrous. I left the bracket in the bed all the time but I removed the bottle for daily driving and plugged the feed hose just to keep it clean; the bracket never got in the way of anything including my bed extender. I had the bottle mounted in the bed and used the DynoTune Nitrous switch center to run it all in place of a standard switch set.
charonblk07
charonblk07
Calgary, Ab
F1-A forged 349ci
Bump for cheap hp and a complete bolt in kit.
Status
