Fox to replace my bils?
aber787
ny
i just replaced my bils with fox coil overs, i had bad tire wear, annoying vibs at highway speeds and i thought it was from the 37inch mud tires, nope. put the fox on it it rides just as smooth as my lexus. plus the bils sagged a good inch and half over time. worth the money for the complete setup vs having to rip apart the stock stuff and reuse old springs.
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Did you end up with about 1 3/4" lift as well? I was hoping to get closer to that 2" mark
joepizuro
Magnum v10
I bought fox 2.0 for my 2nd Gen 2500 dodgeofdroad was like 450 for all 4
joepizuro
Magnum v10
I need some new bolts for lower mounting tho..
aber787
ny
it re leveled my front to about the same height when i originally installed the bils. i set them at 2.1 setting. dont have any exact measurements for you. my alignment went back inspect at least. the coil adjusters were set in the middle so not sure if you can get more out of them looks like you can but i just put them in how they came and they sat fine for what i needed.
Csanders1992
The 1500 have coilovers in the front which are 400 bucks a pop. The rear are only like 120 a pop
